My transmission seems to be leaking fluid from the rear right where the driveshaft goes into the transmission. I only have a small puddle when it sits after driving, but it has blown all over the underbody and exhaust from leaking while driving. I plan on pulling the driveshaft this week to see what is going on. But before I do that, is there a seal in there that I can replace? I looked at the TSRM online and I couldn't tell if it was a seal or just a bearing that the driveshaft yoke sits in. Do you have any suggestions on what I should look for? Thanks in advance.
