I have a 2jz with 1jz flywheel and a r154 transmission plans are 400-500hp range and a daily with spirited driving no track or drag...maybe once at supra meet :naughty:
so here is the line up im looking at.
this full face seems to weak:
http://store.driftmotion.com/static/i-ts2-hdss.php
aron at DM.com insisted on this clutch but ive never heard of action?
http://store.driftmotion.com/static/i-actionstage3clutchkitforr154.php
this is the same PP ^ but with a Puck disc-maybe good for price?
http://store.driftmotion.com/static/i-ts2-hdg6.php
this one seem alot like the DM.com ^ as mentioned above but with a higher price
http://www.horsepowerfreaks.com/partdetails/HPF/Clutch/Clutch_Kits/Bronze_-_Supra_MK3_Turbo/2663
found this one for cheaper on other sites, this is the details of it,not sure of spec clutch, good?
http://www.suprastore.com/spst3clkit19.html
this one has been metioned a few times on suprafourms. but im not sure which feramic clutch there talking about so here is the full face and puck
http://www.horsepowerfreaks.com/par...ch_Kits/Feramic_6_puck_-_Supra_MK3_Turbo/5170
http://www.horsepowerfreaks.com/par...Kits/Feramic_Full_Face_-_Supra_MK3_Turbo/7017
im open to other options, i kinda like the ACT HD pressure plate reviews because there not so hard on the thrust bearings of a JZ motor. id like to stay below the $700 price tag but if its around that or if it means do it right once ill spend a little more i can bend the budget.
thank for the help in advance!
