R154 shifter is it still good to use
St!LL b0oStEd
94
san antonio
Pulled my motor and tranny out my shifter was loose so decided to take it apart and see what the problem was ,also dose anyone know where I can buy replacement studs or bolts that screw on the side that hold the shifter in place
Another if not anyone have a shifter for sale :naughty:
toyotanos
What will we break today?
2,841
Coon Rapids, MN
That doesn't look like it was designed for the Supra. Looks more like a Honda style shifter to me. I'd recommend grabbing a used OEM shift lever. How are the guide studs in the shifter housing? Looks like one has taken a beating.
St!LL b0oStEd
94
san antonio
I was trying to find a replacement but didn't find one that looked liked this one , now it makes sense , and as for the guides I would need to replace both . Are they replicable and who's sells them , I ordered the seat bushing for the shifter and also order the little white nipple that grabs the bottom of the shifter ..
toyotanos
2,841
Coon Rapids, MN
Nope, they're part of the housing and not serviceable (through Toyota). You'll need the entire upper shifter housing. You'll also need the 6 bushings, and the large gasket underneath- none of which are cheap. IMO, you'd do well to search the classifieds for a broken R154 that has a good upper housing just for that reason.
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,249
Charleston, SC
That sorta looks like the cheapie made in China ebay short shifter to me. Although I've never seen one retain it's chrome long enough to wear out like that.
toyotanos
2,841
Coon Rapids, MN
I don't believe so. The housing bolt spacings look different from pictures.
The shifter itself is the same between the two, though.
St!LL b0oStEd
94
san antonio
image.jpg well after browsing the Internet finally found out what shifter the guy I bought my car from was using, why I have no idea just made a mess for me to fix :aigo:
