R154 leak seal problem? help
JP85MX73
79
NY
Im doing a 1j swap into my x7 and when i was test fitting the engine as the tranny pointed down on an angle all the fluid leaked out of the driveshaft hole.. does this mean i have a bad seal?? or is this normal?
gaboonviper85
3,236
Northeast Philly
The driveshaft yoke acts as a plug....the rear tailhousing seal seals around the driveshaft similar to an engines rear/front main seals....or cam seals.
As sc said (100% normal!)
