R154 filler plug location. Need quick reply!
scotty
476
Norway
scottnicholas.net
Hi,
There are two 24 size plugs, one on each side. The one is placed lower and is on left side of tranny, the other plug is further to the back of the tranny/car, and is a bit higher. Is that the filler plug?
Thanks
Scott
super.secret.supra.club
1,304
San Diego, CA
the ones in the back is for he shifter return, the one on the bottom is the drain, the one on the side is the filler. use a manual pump if your gonna put fluid through the side.
scotty
476
Norway
scottnicholas.net
They are both on the sides. I've got not plug on the bottom, only on the sides. As i wrote in the first post, there is one on the side which is right at the bottom, and there is another one which is just beside the gearbox bracket by the driveshaft.
Also there is one which is about in the middle of the gearbox on the left side, but it's bigger then 24 and has a wire connection on the outside of it.
Which one?
