R154 experts needed
MK3Supraman
67
olathe,ks
ok so went runnin it
1st then went to shift second and there it went no second... its a bitch to pull out then slow go to put it in first it goes for two maybe three miles then try to put in neutral an i let out the clutch boom stil in first then there goes first when i finally get it out
so no first or second
then try backin off the light and cant get in reverse
get it home in third poor clutch and here it sits
NOW
im hearing the 1-2-r shifter fork could be the culprite... i try to put it in it seems to go an nothing but puttin it in i dont feel the gears engage so im pretty sure this is it
so can anyone tell or better show a picture of how to get to or replace the 1-2-r shifter fork or atleast how much of a bitch its goin to be to replace??
Doward
4,245
Alachua, FL
You have to disassemble pretty much the entire transmission. Good opportunity for you to do a rebuild while you are in there, or have it professionally rebuilt!
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
your post sucks. next time make it easier to read.
well you could just split the case, pull the rails out, change the fork leaving all the gears and shafts assembled, and be on your way. but at that point if you have the cash you might as well get it rebuilt. i say if you have the cash go for it. if you don't just change the fork. this happened to someone a couple months ago except he broke the bolt that holds the fork to the rail and i think he decided to just change the bolt. and thanks to my online diagnosis he know exactly what to look for. :naughty:
and that is most likely what is wrong with yours. its just a .02 cent bolt. when you bust a fork there is usually a horrible sound that you will hear as the broken fork gets beat to even more shit...
edit: then again i don't know how mechanically incline you are so this might be a bad idea. depending on you experience you might want to take it to a professional.
MK3Supraman
67
olathe,ks
well im getting another trans tomorrow but i still want to tear into it and fix it to have a spare but i want to do it myself
i can do almost anything but ive never torn into the trans
tsupranami
Drain Bamaged
Mar 11, 2006
134
Eastern WA
If you want to do it yourself, you'll need access to a good press and some bearing pullers/splitters. You might not need one if you're just chasing down a bent shift fork, but if you want to replace synchros or bearings, a good press is a must.
You'll also want to have the TSRM handy...
boostin300
52
Las vegas
Marlin Crawler does the best rebuilds on these. Just over $1000 and you never have to worry about your tranny again unless you run without oil or a bad misshift.
tsupranami
Drain Bamaged
Mar 11, 2006
134
Eastern WA
They'll also sell you beefed-up parts if you want to do it yourself to save a few bucks and learn your tranny inside-and-out in the process.
Doward
4,245
Alachua, FL
I also do rebuilds on these (basic or blueprinted) and can get you the entire rebuild kit + all of MC's goodies for $375 + s/h ;)
boostin300
52
Las vegas
Yep, MC does sell parts separately. You better know what you're doing though, there's a ton you can do wrong when rebuilding a tranny. Definitely NOT a DIY if you don't know what's going on in there. I personally know I would f*** up trying to rebuild a tranny :biglaugh: .. theres a surprisingly huge amount of parts that come outta those things.
^ I love that socialism avatar lmao. It's sadly true and sadly what's to come in the next 3.5 years .. :(
And OP, heck PM that guy ^ about the rebuild. Guys like him that do multiple rebuilds get all the screw-ups out of the way in the first few rebuilds and generally know what they're doing a lot better than someone who has never taken apart a tranny. I would know from taking apart my W58 LOL
