My slave cylinder went bad while I was driving, so I decided to replace it and the clutch master cylinder. No problem right? Well, as I was bleeding out the slave, I noticed the clutch pedal would never get any stiffer. I took the inspection plate off the transmission and the clutch fork has come off its assembly.
I'm not too familiar with the R154 since this is my first Toyota ever, but does the transmission have to come out in order for me to get the clutch fork back on, or is it possible to install it while the transmission is still bolted up to the engine?
I did try to put the fork back in to match up with the slave, but it keeps falling back out. I took a small flashlight to peek inside and I don't see any kind of way for the fork to hold in place. Is there a bracket or something to bolt down or hold the fork? Thanks for any help or suggestions.
