R154 2jzgte
Flateric
946
Calgary, Alberta, Canada
Ya, what he said. Doing a 2jz swap hey? Nice to see more of them coming along, did the swap with the same year and motor/tranny combo myself. Let me know if you need any help.
Good luck man, make a build thread.
whitemike;1614769 said:
The 2JZ was never offered with the R154, but the 1JZ was. The 1JZ and 2JZ share bellhousing bolt patterns.
Having said that:
1) You need a 1JZ bellhousing to fit the R154 (http://store.driftmotion.com/static/i-1jz2jzr154bellhousing.php)
2) You need a 1JZ flywheel (http://store.driftmotion.com/static/i-1jzr154flywheel.php)
3) I believe you can use any 7m clutch
Yea I know the 2jz didn't come with the r154. What I was saying is that in order to use the r154 on the 2j I need a different bellhousing and flywheel? Is that correct?
Good luck.
whitemike
1,164
Winter Park, Florida, United States
I never said you didn't know. I actually gave you a list with links and everything.. if you can't figure it out from here man..
I was simply stating that the 1JZ and 2JZ share bellhousing patterns, and that the 1JZ *WAS* offered with the R154 whereas the 2JZ wasn't. Please re-read before re-asking questions..
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
a simple search would have yielded plenty of answers to this.. taken from this STICKY: http://www.supramania.com/forums/showthread.php?29117-1JZ-places-for-tech-swap-and-parts
"Ok... I have a rare engine... where do I get parts in North America???
I have seen many people asking one of two questions:
A. Where can I get parts for my 1JZ?
B. What parts are interchangable between the 1JZ and the 7M or 2JZ?
I have posted the following list a couple of times on various forums but I figured I should finally post it someplace permanent. So here you go... this is what is interchangable between the 3 engines... the 7M, the 1JZ-GTE, and the 2JZ-GTE. Also below I have added where you can source a few of the other common parts for the 1JZ engine. Anyone who sees errors or has additions please contact me and I will keep this list up to date.
Common parts between the 7M and 1JZ
- Clutch kits (but not flywheel)
- Cat back Exhausts
- 89+ motor mounts (rubber part)
- Anything trans (R154) related
- Anything gauge related
- Rad (if you're not using the 1J hydro fan setup)
- Driveshaft/Diff
Common parts between the 2JZ and 1JZ
- Power steering pump
- Alternator
- Spark plugs (ngk 3330 and 6097)
- US spec 550cc injectors (resistor pack needed)
- JDM Spec 440cc injectors (drop in upgrade)
- Water Pump (requires removal of the 1J hydro fan and a 2J pulley)
- Head gasket (although most other gaskets do not swap, get a 1J set to do it right)
- Clutch fan (if you use a MKIV water pump and pulley)
- Serpentine belt (but NOT timing belt - see below)
- Oil filter and relocation kits
- Intercooler kits
- Plug coils
- Cam gears (incl aftermarket adjustable)
- JDM 2JZ Map sensor
- Ignitor
(edit: some more added info)
1) The rod and main bearings.
2) The head bolts, crank and rod bolts from stock or ARP either bolts or studs w/nuts.
3) The pistons including the wrist pins, wrings and locks.
4) The head gasket, stock or aftermarket.
5) stock side feed or after market side feed high ohm injectors. Low ohm injectors require wiring in the 7M or preferably 2JZ injector resistor pack.
6) Water pump and housing when replacing the hydro fan to electric or clutch fan.
7) Cams are normally not interchangeable with out some grinding on the 2JZ cam and having it spun balanced, HKS, Jun and Blitz all make 256, 264, and 272 cams for the 1JZ.
8) Cam shims, springs, retainers, Valves and springs, along with buckets are interchangeable.
9) turbos are not directly interchangeable and require a degree of machining to swap out the 12As for 12b.
The list will be updated as I remember and acquire more info.
(my edit: i am not sure about this timing belt) has been confirmed bellow by a member that this does work Oct-21-2006
For a 1JZ timing belt:
The 1988+ Isuzu Trooper 4 cylinder 2.6 liter engine (4ZEL) uses the same belt as the Toyota 1JZ engine. So instead of getting a belt from Japan (~$100) you can pick up an Isuzu Trooper belt locally at an auto parts store for about $30 US. Make Sure You Get The 4 Cylinder 2.6 Litre Engine Belt!
Timing belt specs: 137 teeth, 25mm wide"
OK to make sure were all on the same page ..i have drawn it..i would like to know if this will work...
WILL THIS WORK
2JZ---R154 FLYWHEEL FOR JZ MOTOR-----CLUTCH OUT OF MK3 TURBO...R154 BELLHOUSING TO JZ MOTOR---R154
Please correct if wrong
---------- Post added at 11:09 PM ---------- Previous post was at 11:08 PM ----------
if image doesnt work heres the link http://img153.imageshack.us/i/r154i.jpg/
OneJArpus
2,798
WILL THIS WORK
R154 FLYWHEEL FROM A JZA70 YES IT WILL WORK
CLUTCH KIT FOR A 7M YES IT WILL WORK
1JZ BELL HOUSING YES IT WILL WORK WITH A 2JZ
I have a 2jz bottom end, 1jz bell housing, 1jz flywheel, and 7M clutch kit. YES it all works
and before i leave, YES IT ALL WORKS
