R-154 Drive Shaft This is not correct is it?
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Alright well when i got the car I got underneath, which I am right now as you can tell, and I noticed that the drive shaft was not all the way into the rear of the transmission. I know it goes in more, because I am leaking transmission fluid a little,
Now as you can see the middle carrier has been moved all the way forward and I still don't understand why it's not fitting here please give me some answers.
I took the rear end out just got done painting a new one so it's nice.
thanks
As you can tell that is the gap I am dealing with here are some more pic's though.
As you can tell I even moved the carrier and no real difference, what is going on!
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
to me it looks like you have an auto front half.
you will need to purchase or source a true 5spd turbo front half drive shaft, and replace the tranny rear seal when you go to install it.
the sooner the better btw..
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
You know I was thinking the same thing sort of. I thought it may be a auto transmission drive shaft.. I got it like this of course so I do not know anything, I took off my rear lugs and found out they were only on there with less then 10 ft-lbs.. so I am inspecting this car. I am nearly done though, I am cleaning the under body ( there a small amount of oil build up ) nothing to bad but I am cleaning it anyhow.
Well, I guess we'll see what happens.
SWD Fredester 3
675
baltimore maryland
Since you have to buy a new front half you might want to consider an
after market single piece. I got an aluminum one from "The Drive Shaft Shop"
and it installed easily and fit like a glove.
