Quieter exhaust?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,240
Atlanta
I was looking to quiet down my exhaust quite a bit, and was wondering what I should use. I have a 3"dp going into a 3" cat, and then back to a generic 3" N1 type can via 3" piping. Would placing a bullet style muffler inline after the cat give me a significant reduction in sound? Or, should I really be considering an oval-style muffler instead? When a muffler is called a 'turbo muffler"(like dynomax or magnaflow, etc.), is it really acceptable for turbo use? I would like to get it down to only marginally louder than stock if possible.
Thanks.
cuel
1,536
Baytown, Texas
I had a similar problem on mine. Put a magnaflow 24" long, 3" diameter, glass pack in where the stock resonator should be. Made a considerable difference in the sound level and tone. 87 n/a.
themadhatter
760
Vegas
well like cuel said a inline glasspack like an bullit is going to quiet it down a fare amount but its still going to be much louder then stock. If you really want it to be just a tad louder then stock i would suggest just getting a dynomax turbo muffler.
dugums
Better, Faster, Stronger
Apr 10, 2007
699
Chicago, IL
My setup is super quiet at idle/normal cruising. I have a recirculated DDP, 3" high-flow cat, and a Tanabe SMH cat-back.
The Tanabe system has a large resonator and muffler. I have seen similar resonators available for $50 and up.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
935 sells a muffler for what you need, I've even heard them on 4 banger domestics around here, a lot better sounding than the other fart cans most of them use around here, nice and mellow sounding.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,240
Atlanta
Well, here's my ultimate plan:
I want to go from a recirc DP which ends in a small flex section, from there to the cat, which will end in a 3pt flange. Then a nice quiet freeflow muffler which will be flanged on both ends so that I can take it out at my discretion. I can simply have a matching-length straight pipe to replace it at will. From there, the piping will head back towards th rear, where it will become a 3" Y-pipe to 2 seperate 2.5" outlets, each feeding an N1 type muffler. Both mufflers will be placed together as opposed to dual exhausts. This way, it'll look a bit different, and I can adjust the sound level with the use of the primary muffler plus the two N1 inserts. If I use 2.5" inlets mufflers at the back, I think they can both fit side by side, and still not cause much exhaust restriction, in fact, less restriction than a single 3" unit.
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
Is it the louder than stock sound that's bothering you, or is it the droning sound the exhaust makes at low rpms when you step on the gas or going up a hill at low rpms?
For me it's the droning sound that fills up your ears when I gass it at low rpm. It seems to go away as the motor transitions into the higher rjpm range.
