quick ?
1_slo_92
145
Hillsboro Ohio
Ok guys I have noticed the past 2 times I have started up my car it sounds like theres a miss in the motor. I have checked everything. the only thing I can think of is my exhaust mani's front bolt (behind the powersteering) needs helicoiled but im holding off untill I get my new setup since I do not drive the car it's just parked in my garage for the time being. Any idea's? Oh and no codes i already checked.
How long has it been parked? I'm thinking it could need new plugs and wires as well, but I'm not a mechanic, nor do I play one on T.V...............good luck
1_slo_92
145
Hillsboro Ohio
.40 Toyota pistons with Toyota rings
New Toyota main and rod bearings
New rod bushings
ARP main and rod bolts
New Toyota water pump
Newer belts
New timing belt and tension spring
New thermostat and radiator cap
New Toyota oil pump
All new seals and gaskets
New Pass. Motor mount
New power steering pump
New upper and lower radiator hoses
New oil overflow hose
4 puck clutch w/ new TOB assembly
Fidennza flywheel
Rebuilt master and slave cylinders for clutch
Mobil 1 10W30 synthetic
Relocated oil cooler
Relocated coolant overflow
Silicone vacuum lines
Head:
3 angle valve job
New Toyota valve seals and springs
2.0 Titan MHG w/ ARP bolts retourqed
NA cam shafts
New heater union and hose
EGR eliminated
A/C eliminated
NGK 1 range colder plugs and wires
Fuel:
255LPH Fuel pump
Aero Adjustable fuel pressure regulator w/gauge
FPD removal kit
Newer fuel filter
Nothing but high octane used at all times
Cleaned stock 440cc injectors
Turbo: .
Larger front mount
Custom IC pipes. 2.5” steel lower and 2,5” aluminum upper w/ rolled ends and silicone couplers
Turbo XS RFL BOV
Catch can
Electronics:
Autometer EGR Guage
Greddy TT
CD player w/ AM/FM ( cd doesn’t work though)
Pioneer speakers
Power antenna broke but in the up position
Silverstar headlights
Dual electric fans
Suspension:
Tokico Illumina 2’s all around w/ new bump stops
Eibach springs all around
Front Greddy STB
Brakes:
Newer stock front pads and rotors
New stock rear pads and rotors
New stock e brake shoes and assembly
Body:
Newer targa seals
Newer front and rear seals for targa
Newer rear hatch seal
Knock sensor rewire
Exhaust:
Titan 3” test pipe
Blitz 3” Nur Spec catback
Car has been sitting for 2 months but it does not do this after it's warmed up.
mkiiSupraMan18
Needs a new username...
United States
1_slo_92Car has been sitting for 2 months but it does not do this after it's warmed up.[/QUOTE said:
Another situation that brings up the "then why worry about it?"
Thats a huge ass list of things you've done to the car, btw. I skimmed through it saying "Ill take that... that... that and that...." but being poor sucks.
Seriously though, if it went away once it was warmed up, I personally wouldn't screw with it. Mine has a slight miss in it all the time, and I don't worry about it even then because it still runs/drives good.
1_slo_92
145
Hillsboro Ohio
well im trying to make sure it's 100% by this spring since im getting ready to order my maft-pro and new turbo in the next few weeks. I just want to make sure it is running 100% before I take it to opening day to do some test and tune on it.
