After initial base tuning and the Mode 4 switch is set to ON (up, done after ignition off for 10 seconds and key removed) for RPM based tuning, do you reset all the dials to "0" and then turn the car back on or do the dials stay in the same positions you put them for base tuning and those are now your initial reference points for rpm based corrections?
It seems to me like I should be flipping the mode 4 switch to ON (which is supposed to save settings) and then putting the idle, mid and wot dials back at "0" for rpm corrections, then turning the car back on. Or do I just leave them where they are and turn them left/right from there to make my adjustments?
