Quick SAFCII question
mtoxracerfss
Boost Addict
Oct 8, 2005
177
Toledo
If i install an SAFC and do not adjust the air flow correction at all it will run my stock map correct? Nothing will change? I know it sounds stupid but i want to make sure.
miggles
i wasnt speeding officer
Jun 3, 2005
526
perth West Australia
Ive got a AVO boostcut that i want to plug in along with my already installed safc2. The problem is one of the wires from the boostcut and the wire from the safc2 connect to the same wire on the ecu. Its the signal going to the ecu after its passed through the safc/boostcut.
I had it plugged in with my safc previously and had 90% of the time with no boostcut.
Ive tried having it around one before the other and vice versa.
My question is What wire do i put closest to the ecu. safc2 or the boostcut?
