So I plan on changing the head gasket on my 87 7mgte. I'm taking off the head ONLY and will probably machine it. However, I am holding the job off until it gets warm out again.
My questions are:
Will draining out the oil and antifreeze before I do this be a good idea? Or should I just leave it in there and drain it once I begin the job?
Should I use ARP head bolts or studs? What exactly is the difference between the two?
My questions are:
