quick question regarding the mk3
Drew1021
red hok, ny
Whats up guys? The name is Drew, im new to the whole supra scene. Originally a die hard mustang fan/owner and decided to try something different. Anyway, i have a 88 7mgte and just changed all the fluids, checked the compression to make sure the headgasket is good, changed the thermostat, and just making sure the car is up to date. I noticed, however, that the car's clutch fan, is really f***in loud. I feel like it takes away from the sound of the car and makes it sound like i turned on a portable fan. Where could i get a quieter fan?
Drew
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
I had the clutch on my fan lock up once. It was loud then, but definitely not working properly. It will be loud with the hood up, but you shouldn't be able to hear it from inside the car with the hood down.
Drew1021
red hok, ny
its only loud when i rev it. the only other time i hear it is when im getting on the gas pretty hard near something that is close to the road where it can reflect sound. just bugs me.
Drew1021
red hok, ny
also... i have like 7-8k that i can put into the car. im buying coilovers and wheels which will leave me 6k. If i dump all 6 grand into engine work, what should i get to make this 7m more then 500hp.
Turbo Habanero
4,229
Tucson,AZ
Full 3inch Exhaust $600-1000
Intercooler kit with 2.5 inch pipes $500 @ Driftmotion.com
AEM Standalone $1400 from Driftmotion.com
Upgraded Turbo for 500whp Driftmotion t4 60-1 kit $1700
Fuel pump Walbro 400 should do it $200
larger fuel injectors $200-400
AFPR $280
Clutch and pressure plate to hold power $550-700 if you have a R154 trans
This is just a small list of what you'll need to get started on your goal performance wise.
Now i think you should at the very least take out the motor and get the block and head decked for a MHG and replace all engine gaskets and hoses.
Also if your car is auto you will to do some work to that trans to get it to hold that power.
89gte
Regular
Apr 26, 2011
134
Tennessee
AFPR $280
I only spent 300 on a full 3in turbo exhaust w/ a resonator and tip. I wouldn't spend that money on Driftmotion's kit, I bought it. It is not plug and play like they describe, and I had to modify for the intercooler itself (the intercooler is pretty thick, but it is not a front mount). It would be easier (and much cheaper) to make your own intercooler kit.
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Other proceedural advise:
Decide on your turbo FIRST. This decision will affect your exhaust choices, intercooler choices, and ultimately how much power your setup will be capable of.
If you're going to go FFIM, decide on that, too, since it will likewise have some far reaching consequences, and you don't actually have the money to buy stuff more than once if you're going to go for good stuff. If you are going FFIM, your budget gets tight.
Driftmotion's intercooler kit is pretty generic, but I have their 2.5" Spearco replica, and I'm very happy with it. The 2.5" piping kit is totally generic, as in cut your own to fit. I want to do mine over again, since I have more couplers in the line than I really wanted, but it has enough parts to make stuff work. You may well want to get a shop to custom fab something for you.
So, turbo first. Then intake and exhaust plumbing. All this can be done running everything else stock so far (Though fuel cut won't be far off with stock electronics, even at stock boost levels.)
After this, and before cranking up the boost (Maybe start here, even) I'd toughen up the engine. Forged pistons and rods, metal head gasket, and some ARP hardware to hold things together. Really, you'll dump a couple of grand into this stage, but if you don't do it first, you'll pay the price later. Expect to lay out a couple grand on parts alone here. For me, I've got shot-peened stock rods, so I didn't buy the forged ones. My pistons (Arias forged) were about $700, another couple hundred on a Titan MHG, More on ARP head studs, plus new oil pump (Good insurance) new water pump, new timing belt. The bill from the machine shop would have been a bit over 2 grand if they weren't one of my clients and I scored a great deal. This is with the machine shop assembling NOTHING, though they did polish 2 cranks for me. Add in the oil filter relocation and full-flow oil cooler kit, and I'm probably $4k in with the bare block on the stand. That's with no turbo, (I already have an aftermarket 60-1) no exhaust, (I already have one that's 80mm turbo-back - LIPP elbow, RT downpipe, and Tanabe exhaust) no intercooler (Already had, plus HKS SSQV) and no electronics. Also, that doesn't include cost for the rods. Wouldn't be hard to put $5k into the block. Oh, mine DOES include a valve job, but NOT doing the shims for the cams.
So I get you at $5500-$6000 with a block built to make 500HP, and a turbo, intercooler and exhaust that can get you there, but not enough fuel, or engine management to get you past 300HP.
The cheapest way to 400 at this point is 550cc injectors and a Lexus AFM, with an AFPR and a fuel pump, which is about as far as you go with your budget, but later, you can get larger injectors and a stand-alone to get the rest of the way to your goal.
At 500, the 7M-GTE is very doable. For 600-800 or so, then your first step is probably to buy a 2JZ-GTE and start planning your swap, since it'll probably be cheaper than the 7M.
Drew1021
red hok, ny
thats what i was thinking over. someone mention to me that a 2jzgte TT swap will run me 5k or if i do single its 6k. but that motor has alot more potential so i might just do a swap and leave it stock besides the bpu's... for now atleast. By next summer im making my goal over 800rwhp..
