quick question on NA-T
suprabones
73
Cleveland Ohio
Hey peeps :biglaugh: I have a quick question for anyone out there that has done the NA-T swap... I am in process now. I am not actually going to put a turbo on for awhile, but I am doing the electronics half of the swap, I have a 1988 mk3 turbo harness and ecu in car, will the NA's TPS work with my harness or will I have to put on a turbo TPS? I am trying to keep the stock y-pipe, I am locating my coil pack to the firewall. Also can I use the 7mge plug wires? or do I have to get the 7m-gte wires?
yankiwi
221
DFW
The TPS will work fine, the turbo/NA use the same plug. You may have trouble getting the plug from your turbo harness to reach though, as if I remember the TPS faces the other way on an NA intake. I did this and it did reach, it was just tight.
You will need turbo plug wires. The end that clips into the coilpack is different.
viper92086
932
NJ
Here's my na-t setup, hope this helps. BTW i tried puttin my coilpacks on the firewall and there is no room, but i can be wrong
s383mmber1
3,614
Somers New York
If you search for my build thread, youll see everything i did. Depicts everything needed to go NA-T.
Feel free to ask us any questions, as there a now a few more NA-T'ers than back in the day :)
