Quick Question on Maft Pro reacting with stock GTE ECU
Turbo Habanero
4,229
Tucson,AZ
I know the Stock ECU reacts and part throttle causing lean afr's under boost on VPC/AFC setup's
So my question is this a big concern or common with MAFT Pro's?
I am using a Stock Toyota Head gasket so staying away from detonation is important and i wanted to know from the experienced if the MAFT PRO can provide this for me.
This is my deciding factor from going MAFT now or saving for Stand Alone (PRO EFI)
My power goal is 500hp with the MAFT PRO.
i will also be going e85 as it's higher octane and i believe (correct me if i am wrong) it's less prone to detonation.
tyang82
487
Milwaukee
You got your car back huh? Bet you was happy like a kid on Christmas morning.
To answer your question........................ someone that knows will chime in lol
Turbo Habanero
4,229
Tucson,AZ
Yes alot of hard work and saving got me my temp Drive license my car and i have pocketed some cash i have been working like a dog 80 hours a week 2 jobs to get myself out :) well worth the Supra though
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
I have been fighting this issue with mine.. there are options to correct the issue but they throw engine codes... I got a lot of help from igotadiesel an CajunKenny so maybe one o them will post on here but personally I am considering megasquirt and pitching maft pro because where I lives there are corners and hills everywhere and I couldn't get any feedback from anyone as to how to fix the part throttle boost issue without causing other issues....... but i have had quite a few people help me along the way who seem to like it lots .... if you en up going maft pro make sure u get a exhaust temp sensor/gauge
Sent from my C771
Turbo Habanero
4,229
Tucson,AZ
Sent from my C771
Thankyou i have the AEM EGT gauge and senor in my car although i have no idea what i'm looking at i know it was a good investment to go with when i bought my wideband
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
here is a clip from by thread i thought u might find helpful
Originally Posted by jdmfreak
went on a test drive today the o2 sim works like it should lost power steering belt for like 20th time :/ goin right back out to put another one on
i didnt get any logs and i kept it out of boost but i got to thinking ...
now that i have o2 sensor hooked up to tccs i run in closed loop exept during warmup and at wot. correct???
and the stock computer tries to keep afr at 14.7
so wont i be wayyyy to lean during part throttle boost??? and if i set up ptt or mid user tune the tccs will fight me ???
originally posted by gottadiesel
Yes and no... how is that for an answer... the TCCS actually will go into open loop before WOT, as far as I am aware it is an algorithm with several factors that the ECU decides to go into open loop, for example, if I hold 6psi of boost at 70% throttle lets say for more than 2 or 3 seconds, it goes to open loop. The time to be careful is pulling a long hill and running that 3-5psi of boost while it is still at 14.7, this is why I also run an EGT gauge so that I can watch and make sure it is not getting too hot... Is your EGR system still intact?
Do not use PTT, we will use the VE table for fine tuning, as opposed to the low/mid/high tune settings on the unit...
and just in case u feel like reading
http://www.supramania.com/forums/sh...can-i-get-a-good-tune-on-maft-by-myself/page3
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Jordan, the MAFT pro does a slightly better job of part throttle than the older piggybacks, but bottom line, it still suffers the same challenges. For 500whp, I'd be upgrading to a standalone or forged pistons... or more likely both.
Turbo Habanero
4,229
Tucson,AZ
Thanks Grim and JDM
Grim i'm having a hard time on deciding i know the stock pistons wont hold forever i plan on building a spare block and head just to have for when this one gives up. Kinda of curious with taking the right steps on how long i can push and make this thing last :)
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Turbo Habanero;1812198 said:
Thanks Grim and JDM
I did *exactly* that with my 7M car. Built a second engine with forged pistons, had it sitting on a stand for when I popped the one in the car - which had a MHG and ARP bolts, but the pistons were still OEM.
Pushed the power up, drove it for a couple weeks, pushed it up again, drove it, etc, etc. Damn thing lasted over a year! Eventually I was running over 20psi, on a 60-1 upgraded CT, stock fuel... that finally popped it. Mind you, it did a *really* damn fine job of popping it. Destroyed the ringlands on several pistons, melted two more, and killed the head gasket in literally every cylinder. Oh, and killed the bearings on 2 more.
Turbo Habanero
4,229
Tucson,AZ
Damn yeah as far as fuel i just ordered a walbro and Aeromotive afpr and plan on running e85
I have stock gasket with arp studs i decked the head and had the block checked/cleaned by the machine shop and i am also running a 60-1 at the moment so we will see where it goes but i only plan on running it in it's safe limits if it blows i want it to be because it couldn't take anymore not because i lean it out :)
