quick question about WG lines??
Untouchable7mgte
back in the game!
Wilkes-Barre,PA
hey guys i was just thinking about my WG i have and there is a port and the side and one top, i know you have to route them to vaacum but where at? I have a MBC also so how would you set those lines up? Thanks.
Tom Z.
socc924
CT and Philly
Do you have a CT-26. If so the compressor housing has a vacuum port that goes directly to the wastegate. With a MBC you are going to put one end of the controller onto the compressor housing and the other end into the wastegate vacuum port. Hope this helps.
Untouchable7mgte
back in the game!
Wilkes-Barre,PA
its on of the lovly hks knock offs. dont get me started on all the problems i know! But yea it has a top and side port. i guess block of the top one runside to MBC then MBC to vacuum port?
Tom Z.
Idealsupra
Orlando
www.tampabaysupras.com
leave the top one open and run a vacuum line from the side port to the compressor housing....that will run it off the wg spring...if you want to put a mbc just put it inline and youre set....
if youre running an ebc down the road you can use the top port to help control the boost a little better.
