well luckily it started up after i got everything back together. after finding all my coolant leaks (loose hoses) and driving it to the gas station then back, it feels like my car is really hot still. the radiator and upper coolant hoses are to hot to even touch for more than 3 seconds. so i just got a new water pump and hopefully that will make things a little cooler.
when i drove to the gas station and then back one hose was leaking because i forgot to put a clamp on it........would this cause it to be really hot like it was???
before i did this job my car backfired/sputtered/popping sound came from the engine/exhaust. now its the same if not even worse. when this happens it actually shakes the engine and sounds like it wants to just shut off and die. anyone ever have this problem? its really annoying
thanks for the help so far!
