Ok so I was reading through the forums and I noticed on some ones sig, taht they were looking for a system that eliminated the AFM. Is There really a was to do this? Like, is that what a MAFT is, I mean, comon guys, I'm 16.
MAFT and MAFT Gen II will replace the AFM with a GM MAF sensor (still a restriction, but you can get a 3" one and use it in a blow through setup (behind the turbo, instead of in front like the stocker)). The MAFT Pro can replace the stock AFT with a speed density sensor (mentioned above) which means all you have is a pressure and temperature sensor coming out of your plenum, no restriction.
