when running a maft pro, with speed density, and boost control, if everything is hooked up correctly and all the settings are input correctly, the car should idle and rev the same it did before on the stock ECU alone, correct?
dbsupra90;888606 said:it might take a little bit for the stock ecu to relearn, so it may try to idle low or search around a little.
as far as the rev, there is a slight hesitation at initial tip in you will have to try and tune out. it is the worst on version 4.4
GrimJack;888678 said:I had that hesitation in 4.4 as well. I upgraded to a newer revision, and it's been awesome ever since.
Oh, and my setup idles at least as good as stock.
dbsupra90;889672 said:justin, can you please attach or email your xdf file to me?
other than that, be sure your map sensor has a clean signal. best would be if it had its own vac source.
Justin;889761 said:Yeah, I'll work on that... I honestly have not really messed with the maft yet, I was under the assumption(confirmed in the first two posts) that the car should run as it did before the install.
dbsupra90;890105 said:what do you mean you havent messed with it? havent you gone thru and done the configuration/setup after the install?
