EDIT: Sorry posted this in the wrong section
Ok so if you read my update (link in sig), you saw that she is running hella lean at idle. I think I found that problem, the vac line for the heater valve was hanging lose, found it when I tried pressurizing the intake.
BUT while repressurizing the intake to recheck, there is a small hiss coming from the TB. The TB has bearings for the throttle plate "rod". Air is hissing out from the bearing, there is no way to seal that up, the TB "rod" is not held on with a nut, it is pressed into the linkage plate.
So will this leak enough air that I should be concerned about? Or any ideas on how to seal it up?
BTW it is not the stock TB.
