Quick grounding point question (2 near transmission)
bowsercake
828
Irvine, Ca
I have two grounding wires that are hanging near the transmission. One is farther back and I believe that it goes on one of the four bolts that are on the transmission mount. The second ground is near the block and the slave cylinder. Does this ground mount to the block or does it go to the transmission?
5
it goes from the body (where the fuel lines are) to one of the bolts that holds the trannny to the block IIRC...
the other one mounts to the tranny mount
