Do I have to disconnect the rod from the clutch master cylinder, in order to remove the clutch pedal from the car? I've found the pic of 4 bolts to remove, and she's loose, but I can't seem to get her out!
Ahhahaha... not sure why I thought the rod would remove from the master cylinder - there is a clevis pin that has to be removed, then the master cylinder pulls out, and the pedal is sitting there for the taking
