quick BOV question
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
im probably getting the TurboXS RFL BOV...you know..that one with the horn...
would i be hearing the psshhh noise at the slightest give of gas? or just when the turbo starts spooling up?
im auto btw.
Supracentral
12
A blow off valve simply releases pressure from the system when the throttle plate closes. This is to protect the compressor from the shockwave that is generated when the throttle plate slams closed. It also helps the turbo from 100% spooling down during a shift on a manual trans car.
You don't hear a BOV while spooling up. You only hear it when you let off the gas.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
heh, right that. thats what i meant, sorry i just worded it wrong...
but my question is if i give very little gas and then release, will i get a blow off noise? or do i have to have the turbo spooled up to get a blow off sound at the release?
Supracentral
12
This BOV is adjustable. You add "shims" (they are really washers) to adjust how far the pressure differential needs to be before it "blows off" - as long as you are generating some positive boost, and if the valve is set soft enough, it will blow off all the time. The tighter you set it, the more boost you need to be making for it to blow off.
