Question's On installing a FFIM
Turbo Habanero
4,229
Tucson,AZ
So i want to install a FFIM.
I have not bought anything yet and have looked around on tips/tricks but didn't really get much on this.
So my question is what all do i need to do/buy/adjust to install a FFIM on a Basically Stock 7M-GTE. :1zhelp:
Thanks I know i still have alot to learn.
Turbo Habanero
4,229
Tucson,AZ
Justin727;1404211 said:
goto suprasport.com check out their new FFIM. You're going to need a new FMIC and some IC pipes for starters.
I know that but what i was wondering is there one where you don't have to relocate ALT/AC/Battery ??? Also i was wondering if there is a bolt on kit anywhere? I have read some things about it but never find anything around for sale.
This is what caught my attention just wanted to know the details a bit more on installing one. You may have seen this in a other thread. Hell of a deal
http://cgi.ebay.com/ebaymotors/toyo...ies?hash=item4148da9dcf&_trksid=p4506.c0.m245
Justin727
T-virus infected
that doesn't come with an alternator relocation kit and that specific manifold will require the a/c compressor to be gone. Lipp builds the alt relo bracket for that specific type of manifold.
Long Runner like the RonR comes with alt drop down bracket. Wanna say Sethron builds one too with brackets. The only thing bolt on about them is the manifold itself. I do not think the SS one requires alt. relocation but it may. If you use anything else besides the stock TB it will require so modification to a few things.
keep searching my friend there's alot of info on here for it.
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
Check out 92nsx's build thread. He has a FFIM made by funkey_monkey that keeps everything in it's spot. only have to remove the aux a/c fans
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
All depends on the sytle of manifold you will be running check here for styles:
http://www.supramania.com/forums/showthread.php?t=104491
But for a basic list this is what you are looking at:
-New IC and IC pipes
-Lower Alternator long or medium style manifold, remove A/C and place alt there for short style
-New throttle cable
-TB with Stock TPS mounted on it(you will have to extend the wires), you will want to upgrade now and there are lots of options
-Depending on if you keep CSI and ISC, new lines, hoses, and extended wires
-New Vac lines
-Reroute coolant lines under the manifold
-Remove EGR unless you get a kit that retains it
-Short and medium style manifolds require battery relo and junction box relo, long runner both stay in place
This is all I can think of off the top of my head but give me a shoot if you have any other questions.
HTH,
Seth
Turbo Habanero
4,229
Tucson,AZ
-New throttle cable
-New Vac lines
HTH,
Seth
Thanks Seth
I like your work. And will be seeking your help when the time comes as im not sure how to go about some of these things or even knowing what to chose. I am thinking long runner so i can keep my A/C and not relocate the Batt/Fuse box. I will definitely buy from you when i decide to do it thanks again.
Jordan
