My 1.5JZ was "recently" installed. 2 1/2 years ago, but I've only driven it 3k miles due to a year long deployment. It was completely rebuilt, broken in well and it has great compression numbers across all cylinders. Everything was brand new when the motor went in. Turbo, oil pump, hydropump....everything.
I had an oil leak at the front main seal just after the install, which I replaced (a Toyota seal). It continued to have a slow drip. Thinking that it might be from the oil pan, I dropped the sub frame and re-sealed it. Still has the slow drip, one or two drops a day on my garage floor. Thank God that I epoxy coated my garage floor when I bought our house.
Today my son was following me and he said that when I shift gears, it puffs smoke. Hmmm. The head was pulled about a thousand miles ago and it was completely rebuilt (again, with new Toyota seals). I know anything is possible, and I know the something could have gone wrong, but Im starting to wonder if synthetic oil is the culprit. I have heard that full synthetic oils are "too slick" and can pass my perfectly good seals, but Im skeptical by nature.
I know the answer to my question is an oil change away, but hopefully JDub (a known expert) or other seasoned guys can chime in with their experiences. Can my drips and puffs be caused by Mobile 1 oil?
