Hi all.
FFIM almost done.
Stock ecu so no venting to atmosphere, not for me atleast.
If done right I have to weld a small alu pipe just before the tb and run a 20-22 mm hose all over the engine, or under to the pipe before the turbo.
I dont like this at all becuse in the near future the lex afm will be removed.
The Bosch bpv sits on the turbo intake pipe.
How "bad" would it be to just run a hose down to the pressure pipe going between turbo and IC?
That pipe is mild steel and I can cut/weld that myself.
suprafredde
FFIM almost done.
suprafredde
