Question on GM 3 bar Map sensor
retromania
4
OC
I just installed a GM 3 bar MAP sensor on my 1jz setup but was not sure what voltage it is supposed to be reading on the ignition on position. When using the stock MAP sensor I'd get the reading of 2.xx volts, but on the GM 3 bar MAP sensor I would get 0.7 volts. I was wondering if any one can relate some feedback on there 3 bar map sensor voltage on the ignition on position. Thank you!
retromania
4
OC
I just need to know the MAP sensor if it is in proper working order. Are you by any chance using a 3 bar map sensor?
retromania
4
OC
yes ignition on engine off, thank you for the response by the way.
I already saw those links before, but I wanted to know first hand from fellow members using the 3 bar map sensor what their voltages were on their cars.
