So ive been thinking to possibly convert my 4 speed auto to 5 speed manual tranny...how difficult is it to do it? Is it worth it? And by any chance might any of you guys know whats the price range to do this job if taken to a shop? :1zhelp::1zhelp:
SupraFreak619;1834636 said:oh okayy ill search for those write-ups. Well the only thing i can think of that might need to be cut is that extra hole for the clutch pedal right? but do you have any idea what a shop might charge to do it?
Mr Bojangles;1834664 said:I just did this a few weeks ago. There is no cutting involved, there is already a hole in the firewall where the clutch pedal goes to bolt to the master cylinder. Just pull the rubber firewall plug, peel the pre-cut sound deadening material oval off the inside of the firewall and install.
You will need a brake pedal from a manual car as well as a clutch so don't just get the clutch and think you're all set.
ps. do it yourself, it's easy.
I believe you;re also going to need the front half of the drive shaft from a 5 speed car. I don't know for sure because I had a custom aluminum one made.
ifyouaint1sturlast;1834879 said:Here's your parts list man. I've done this on a 7m with r154 and am about to do the swap on my 2jz
-R154 Transmission
-Appropriate bellhousing (7M or JZ)
-Appropriate flywheel (7M or JZ)
-Clutch disc and pressure plate
-Release bearing and fork
-Clutch and brake pedals
-Master and slave cylinders
-Clutch line from master to slave
-Driveshaft (if using stock you can just grab the front half of the R154 shaft as all rear sections are identical)
-R154 transmission mount ($5 on rock auto)
-R154 crossmember (I used my auto one, some people say its different)
-Misc: Bolts, Pilot bearing, Fluid, Shifter, Shift Boot, Shift Knob
Also your trans may or may not come with the ABS sensor. It also may or may not come with the correct speedometer drive (cable vs electronic). It all depends on where you source it from.
You will also need to jumper your auto harness plug to make it think the car is in park. It's a big round three pin plug, jumper the two parallel pins.
Hope that helps. I have a stock clutch for sale slightly used if you wanted it.
Mr Bojangles;1834976 said:If you're going to be putting the 154 behind a 7M you will also need wing brackets that tie the trans to the motor. If you decide to do the swap I have the brackets I can sell you.
