Question for the tunners.
Topher E
Trance Head
Aug 4, 2005
388
Vacaville
Okay, I want to know how many of you are running the GCC/VPC combo? I am hitting fuel cut and rather than get the lex/550 and a tune I want to know if it is possible to run 10-12 psi on the stock afm and injectors. Mods are listed in my sig and im trying not to be a noob. but if a flamefest erupts, oh well.
Again, im not looking for high hp numbers now, i want to be able to floor it all the way thru the gears and not hit fuel cut.
Thanks.
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
vpc will practically get rid of your boost cut, or high enough that you won't hit it. Also with VPC, you won't need an afm. Straight pipe to the turbo, so you can hear it spool.... :bigthumb:
yaitsme
Beach Bum
Mar 2, 2006
245
Cheatham County, TN
I ran 15lbs on the stock fuel system with the vpc/gcc combo.
While I did hit 350+ whp (with other mods, obviously), it was a pretty 'jagged' power curve. (Poke around for my build thread, there's a graph posted there ... but I'll warn you - it's not a pretty thread).
The VPC may not be the cleanest (signal-wise) or the most adjustable (thus the need for a GCC, too) ... but it's proven & still works.
*edit* - Oh yeah ... and total elimination of the AFM is pretty much the point of the VPC (you will have switched to a 'speed density system' instead of that crazy karman-vortex idea that makes our AFM's suck so bad). *end edit ... with disclaimer - I'm just a dumb noob, too*
That said - I'm going standalone with this next build ... the VPC's limited in it's ability to tweak the system low enough for using big injectors (my 1000cc RC's should be arriving soon :naughty: )
Topher E
Trance Head
Aug 4, 2005
388
Vacaville
Are you going to be looking to sell the gcc/vpc?
Any other opnions / experances? Iam looking to buy soething so that i can stop hitting fuel cut soon. Maby within the next month or sooner.
Moar advice would help aid in this decision :3
-Chris
yaitsme
Beach Bum
Mar 2, 2006
245
Cheatham County, TN
Kinda proud of the custom mount I fabbed up for them:
For the moment they're sold ... (I'm supposed to meet the buyer tomorrow).
but ...
I have an extra VPC (w/ hacked harness - damnit) and two HK$ fcd's that you can have for next to nuthin.
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
I have got very minimal mods (cheap intake/3"no cat exhaust/MBC/a few other very minors), and I can hit 14-15 pounds on the stock ct-26. But, of course I have fuel cut with the MBC wide open. I keep it down to about 10-12 with the MBC. Sometimes I still get fuel cut on cool nights.
My point is........can't you control you fuel cut through you EBC, and still get 10-12 lbs?
Also, going against what I have always read, I have recently been hearing people say the Lexus is OK with 440's with a good tune. But you'd want a way to monitor your a/f ratios
Topher E
Trance Head
Aug 4, 2005
388
Vacaville
I thought that would be the case with the ebc but all I can do with the freaking thing is turn down the saverty of the boost. I dont fucking understand why I cant get the car to sit at 10 lbs. I hate it. Its the greddy profec b. I really need some help with tunning.
