I received some fittings to set up my new Oil system with filter relo and full flow cooler. I am using a Permacool Oil thermostat, and the fitting you see below is a 1/2 npt to -8 an fitting. You can clearly see both ends of that fitting, and the difference in exit size. Reading the instruction manual of the thermostat, it say that if using AN fittings, we must drill out the AN side which looks to be restrictive. Is that really necessary? They say it may damage the themostats' valve system if left with that restriction. If I do have to do it, how would I go about enlarging the fitting? With a drill bit? As anyone set-up their system without drilling out the fittings?
Thanks
Thanks
