Hi Anthony,
I decided to try using the stock rack, modified by removal of the PS pump w/a hydraulic flex hose looped on the pinion, valve body. I drove the car around w/o PS for about 6 months like that, before I had the rack and pinion assembly, disassembled and the rack pressure plate seal removed. The purpose: to not be pushing air and fluid around in the rack center housing. This makes turning the steering wheel easier and more precise.
Driving at the limits of the tires adhesion is easier, now that I can feel it beginning to give way. Thanks to the feel through the wheel, I’m able to more accurately place my car on line, time after time. It is still more work to steer when driving below 10 MPH then with PS though.
My Supra isn't meant to be driven on the streets either... I do, but it's not that enjoyable. It's my personal preference to take out all the luxury items Toyota designed into the platform, to lighten the car and I'm pleased how it performs on track, but not the street. A three hour continuous drive on the highways in Oregon and Washington, will leave my hands tingling related to the vibration sent through the rack and pinion to the steering wheel. That never happened before I removed the PS!
What are your goals for your Supra? Van
OfnaRcR4;1759769 said:
Don't do it. Such a little gain for such a big loss. If you're determined to make your car's value less and and make it a bear to turn with an unnoticable gain in horsepower just make sure to fill it up and loop the PS lines.
