Question About rim sizing
Status
Not open for further replies.
senseikrang1
enemyofmankind
Sep 7, 2006
toronto
Hi,
I have a question about rims. I have a 1990 Turbo which currently has some 17" x 7.5" chrome rims on it and I am thinking about changing them.
Can the 2008 Lamborghini Gallardo rim fit on a 90 turbo?
I have seen some supras with wide rims, just wondering.
Thanks,
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
All you have to do is find the specs on those, make sure the they have 5 lug etc..
Though I am not sure how large they are, but if they can fit within the wheel well then go for it.
supramad77
supramad
Feb 5, 2006
331
Dartmouth, Devon, UK
well you will need to give us more detail than that. I would doubt it in any case. I would think there rear wheels would be about 13"s wide. Biggest you can get on the supra is about 10" maybe 11" with the right offset.
You need to tell us what the bolt pattern is and the offset.
senseikrang1
enemyofmankind
Sep 7, 2006
toronto
I believe these are the specs:
BOLT PATTERN: 5 X 112MM.
FRONT WHEEL: 19 X 8.5". OFFSET 41.9 MM W/ 235/35/ZR19.
REAR WHEEL: 19 X 11". OFFSET 55.3 MM W/ 295/30/ZR19.
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
Looks like they won't be working for you, I am sure thee is a set out there that you like.. that will end up working just fine for you, I know I will be going with Enkei rpo3, you should check them out.
Status
