Question about possibly match up 1990 harness to 1989 components???
MightyAl
293
Chesterfield, MO
The chassis plugs under the dash are different from 89 to 90. I think the main power plug from the fuse box in the engine bay might be different also.
Some early 90 will work on 89. I've done it 2 of my friends cars.
If the body plugs fit they will work. But if its a yellow plug car there's going to be some wires that need to be swapped.
Supraholics
.928 RWHP & Climing!
Apr 1, 2006
1,577
PA
www.supraholics.com
It's not going to work, but if you're up to the challenge, get the wiring diagram which indicates which pin is which and re-pin the appropriate plug that fits your chassis. Its more work than it is complex.
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
'89 are grey plug, BUT they are the same pinout as the earlier yellow plug harnesses.
My '89NA was grey plug. I popped in an '87 7M-GTE harness and ECU. It plugged right in, except for the ABS harness, which was easy enough to adapt. I kept the 1989 ABS brain and actuator.
So under my dash, I've got the grey chassis harness plugged straight into a yellow ECU harness. All of my gauges work (With the tach driver board changed out)
If you have a 1989 engine which you are dropping into a 1990 car, I believe that the 1990 harness will connect to the engine in most cases. I also believe that you could use most of the 1989 accessories in the 1990 car, but you'd have to check case by case.
If you have a 1990 engine and harness and are trying to install it in a 1989 chassis, I suggest that you reconsider. Again, the 1989 harness should connect to the 1990 engine in the vast majority of the cases.
