Question about my Turbo and Turbo gauge.
JDMSupra
Hey, I was wondering why my Supra wont show any boost from the gauge when I just rev it with the clutch pulled in, it will only boost with a load and boosts fairly late into the RPM range, should it start building boost faster? Does this happen to all supras or is it just mine, the gauge does not move at all unless hammered in gear 4000+ RPM, also hard to get boost spooling in first gear. thanks.:icon_conf
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
It's usually harder to get boost in 1st compared to other gears, but in 2nd,3rd,etc. you should be boosting sooner than 4k. Stock I hit 6psi by 3,000 in 2nd.
JDMSupra
Im not exactly sure how to read my stock turbo gauge it goes from -2 to +4 but it never shows it going past +2. I have gotten the RPMs to redline and still not much above +2. Can someone tell me how much PSI this is?
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
Do you feel much of a pull once you hit full boost?
If the turbo feels pretty weak the gauge could be right and it could be the turbo, or a boost leak(which you would probably hear)
boost fiend
852
Rockford, Il
i have the stock gauge and a autometer in the car. the autometer hits 10 psi before the stock one even realizes ive hit boost. spend a couple bucks and get a diffrent gauge.
Marcenator
Marc T.
Apr 29, 2005
22
Edmonton, Alberta Canada
Turbo's build boost from energy(heat) produced by the engine under load. Just reving the engine doesn't produce much energy. The stock boost gauge reads in mmhg so +4 is equal to about 7.7 psi. Stock boost is about 4.5 to 6.5 psi. With a stock setup the gauge shoud not go all the way to the top.
Here are some conversions.
MMHG PSI BAR
0 0 0
1 1.9 0.13
2 3.9 0.27
3 5.8 0.40
4 7.7 0.53
5 9.7 0.67
6 11.6 0.80
7 13.5 0.93
7.5 14.5 1
8 15.5 1.07
9 17.4 1.20
10 19.3 1.30
11 21.3 1.50
12 23.2 1.60
A better gauge can help give you a better idea of what you are boosting at.
trydrew
Suprafied
Nov 4, 2005
1,038
Earth
Could it perhaps be a faulty bypass valve..? That would explain no 1st gear spool and low boost. This and a leak might make the problem, and a new gauge wouldnt hurt, especially something more accurate.
One more thing, you normally dont get much if any spool when not under load.
