LoveMy7MGTE said:
thats the thing, my cps is fine, was taken from a running car, and I have spark, but no ijector pulse. oh, and i dicconected my throttle cable to make sure it wasnt overtensioned causing the code 51, cleared codes and the 51 is still there.
I seem to be constantly repeating myself on these idle and TPS issues over several posts. Did you do as I suggest? Did you check the TPS with a meter or short the pins on the harness and see if the code disappears? Your lack of injection is a separate issue. Weren't you the guy who was having Dr Jonez come over for a look see or am I confusing you with someone else? Is your AC turned off when you're doing this?
Jab89: Yep, a code 51 can be set by other than the IDL contacts but that'll only happen during a diag check and only occur when the AC is *on*, not off. It's simply a way to check the AC amplifier circuit without adding more codes.
Lets look at it from an electronic standpoint. The input in question is brought to ground (E2) when the IDL contacts are closed. When the contacts are open the input is "pulled up" to 5 volts by an internal resistor in the ecu. In fact all the inputs are either pulled up or down so they can't "float" when open. It's standard practice, any electronics guys out there will understand what I'm talking about.
The AC switch is not connected to the IDL input. It *is* connected to another input on the ecu however and is used to increase idle speed during AC operation. Since that input is also pulled up there should be no need to fool it when the A/C system is removed. That said, if LoveMy7M is checking codes and has the AC turned on he'll get code 51 even with the throttle closed. I sure hope that's not what we're looking at here. It'll also happen if if there is a problem in the neutral start switch circuit on an auto tranny car.
