I was doing some research here at work on the stock twins with open dump (mine being 3" Trust) and came across an aussie post on how relieving the back pressure does increase power obviously, however that the stock wastegates cant seem to keep up right away with the boost running away due to being small and inadequate for this scenario.
Now im still learning so im sure some of that didnt make all the sense, but the question is does this wastegate problem cause the seals to go bad pre-maturely?
They kept saying that the US guys denied this fact about the twins and would rather go with the 1st gen vs. 2nd Gen 1jz excuse relating to PCV valve and intake piping changes.
I have searched a bit, though at work i cant seem to use the search on the forums.. so if I overlooked posts please forgive me as i usually do extensive browsing before stating a question.
