Question about 1JZ mounts and transmision!
lifesnotfair
356
Dominican Republic
I have two questions:
1. I've found two 1JZ's with MANUAL transmissions here in the Dominican Republic. Can I use that tranny in my '88 MK3? Or does it need custom work to fit in? Because in here, most people with 1JZ's or 2JZ's use the 7M-GTE tranny because those JZ engines almost never come with manual tranny. So, would I be better off buying this engine I found with manual tranny? Or is it recommended to use the 7M-GTE tranny with this engine? (for which I will need a bellhousing, I know).
2. Has anyone used these things, to mount their 1JZ's in their 86-88 MK3? http://www.bicperformance.com/produ...st wondering. I'm considering going this way.
92SupraMan
Supra in Debt
Nov 5, 2005
60
San Diego, Ca
1jz manual trans IS the same as the 7mgte trans, just uses different flywheels and a different bellhousing.
I cant speak from experience on the BIC mounts but everthing I have heard about them is positive. Plus if you use those and decide to go with an aftermarket Y pipe you dont need to grind out the mounts like us 89+ guys do.
lifesnotfair
356
Dominican Republic
Ah, so I guess it should be okay to buy a 1JZ-GTE with the manual tranny, better yet.
The BIC mounts... I mentioned it to a mechanic, and he said "forget about, we solve it"... but I know they WELD the mounts that do not fit. Can someone tell me exactly which mount(s) do not work on 86-88 MK3's for the 1JZ? I wouldn't want them to weld. Maybe I should buy these BIC mounts and just bring them to the mechanis, and say "USE THIS OR DIE!".... =P
92SupraMan
Supra in Debt
Nov 5, 2005
60
San Diego, Ca
The BIC mounts bolt into place on the block and allow you to use your 86-88 mounts. That way you dount have to swap the crossmember to an 89+ and use the 89+ mounts or worse yet weld some weird mount onto the crossmember.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Those BIC mounts look like they would make it pretty easy to drop the motor in. I actually cut a wedge out of the stock mounts on the crossmember and weld it back at a different angle, then the stock 89 up mounts and brackets that come on the clip work fine. But his are a simple bolt on affair and BIC makes nice stuff from what I have seen. We just put his 7m ddp on a Cressida and it is very nice too.
I replied to your pm but your inbox is full:
I have several different fmic's for under $180, depending on the size you want. I have a purfect size one for a 1jz. I will send a pic tomorrow.
