Q's
nsjoel808
17
Hawaii
a couple qs, my clear coat is peeling all over is there any way to make it stop and maybe wetsand the affected areas away. what grit? flat black is better than it being shiny in some areas and peeling everywhere else. looking for a temp fix until i get it repainted
the use to be black trim around hatch has peeled away to chrome any tips on painting it back to black?
if i get the 89 tails will i have to get that molding too, i have an 87t and it has a rubber grayish molding
input would be appreciated
Turbo Habanero
4,229
Tucson,AZ
The hatch moulding is plastic not painted you would need to buy paint that would stay on the metal if you were to paint it and prob something that is kind to flex
InFrnt0fU
Lurking Supra Socialite
To the OP, I suggest you do some reading on on this board and using the search function. People will not want to respond to you if your questions just spew from you head onto this site. There is a superior wealth of knowledge on this forum, searching is your friend!
I always hope the newbies to the board don't take offense to these type of posts, but I thought I'd say something early to break the bad habit from forming.
.02 cents...rm
Just flake the clear off as it comes off. If you wetsand it it will look ok for about a week then it will start peeling again.
Replace the trim. It's a rubber coating over metal that's meant to seal.
89+ tails won't match the molding, up to you...
