Q45 Throttle Body Leakage - Anyone Else
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
So I finally got around to doing a pressure test of my intake system. It turns out that my Q45 throttle body is leaking from the shaft seal. Has anybody else experienced and managed to fix this, or do I get a new (used) TB and hope for the best? If I pushed the throttle arm toward the TB, the leak stopped, though obviously, this is not a permanent fix.
Other leaks found included the EGR modulator...although upon reviewing the TSRM, it seems as though this is expected.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
I was wondering about that...I suppose you are right. At 15 psi, you could barely feel the leak putting your face up to the TB, so there's not a lot of volume lost there.
Holy shit, the throttle plate howled like a motherfucker when pressurized!
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
I'm quite choked since this was an OEM TB (although I suppose not meant for boost)
I'm going to try using vacuum grease on the shaft O-rings and see if that helps.
iceberg319
vvti, what?
Apr 6, 2005
328
NJ
mine does the same thing, i did a google search on how to fix it and i didnt come across anything. someone even tried switching seals and it only helped for a small amount of time.
i also just went through you thread about the driveability with the q45 so im switching back to stock
