Purchased extended harness need insight!
808steeze
28
Hawaii
So I bought a 1jz swap from a guy that gave up on it, only thing is he wanted to put it in a 91-92 (Kouki) cressida. I however put it in an 87 7mgte supra. The problem lies with the wiring harness, when I bought it it was already lengthened. First question does anybody know who lengthens harnesses with red heat shrink. Second question can someone tell me if the white and grey plug are from 1jz or cressida, I have not seen these plugs in any 1jz pictures. I had to buy the pigtail ecu connector off ebay because I had an empty connector with swap.Any wiring advice much appreciated.
ecu wiring 010.JPGecu wiring 011.JPGecu wiring 012.JPGecu wiring 013.JPGecu wiring 014.JPGecu wiring 015.JPGecu wiring 016.JPGBS pics 025.JPG
veedubin
Official SM Decals
I'm not 100% sure with the 1J or 89+, but my 87 has a mate to the white plug coming from the dash harness. As for who lengthened it, that very well could have been a "home-brew" job, i.e. the previous owner could have done that himself. I would definitely get a wiring diagram for the 1J and go through it with a multi-meter to ensure that nothing got crossed, or improperly spliced.
te72
Classifieds Moderator
6,610
7
WHYoming
If nothing else, Dr Tweak does good work, and could probably help troubleshoot yours if it is something minor.
808steeze
28
Hawaii
Thanks for the insight! The only connectors I have under my dash of my 87 7mgte are: a big yellow, small yellow, small white(that the white plug will definetly not fit), the yellow for the flying lead out of the ecu, and the small black for the hac sensor.BS pics 022.JPG
If anyone knows where I can cross refrence this these plugs with some cressida plugs from a 91-92(ie. forum) I would greatly appreciate it.
te72
6,610
7
WHYoming
If JZX Project is still around, I would be willing to bet someone on there could help you with the Cressida info. :)
Failing that, I know we have a few people on here who can point you to a good source...
