You had a thread just a few weeks ago about how you were hitting fuel cut (which will throw a code 34, btw). Based on your last post in that thread:
jamesmwalker79;1519151 said:
ok guys i figured out my problem. my throttle postions sensor was way off got it set to were its suppose to be and wouldn't you know it no more fuel cut off. thanks for the help.
34- Likely a boost leak. Check for cracked, loose IC piping, etc... Pay close attention to the IC side of the turbo, and the coupler after the 3000 pipe.
