Pulley question
JesseH
1,153
Englewood, Ohio, United States
I know this is probably a dumb question but does anyone know if MKIV accesory pulleys are interchangeable with the MKIII or if anyone knows where to get accesory pulleys for the MKIII
souprat
fairfax VA
the general concensus 'round here is that pulleys are not worh it. the crank, water pump, and alternator are things that the engine needs to run properly. if you insist hpf has them, unorthodox has them. just DON'T use anything other than the stock crank pully.
