I had a SP67GT on my car with both a .68 and a .81 housing on it for a T4 flange. The turbo had a p trim with a 3 inch v band adaptor on the back of it and a .70 TO4S compressor housing which has the 4 inch inlet and 2.5 discharge. I made 450 rwhp/418 rwtq @ 16 psi,518 rwhp/475 rwtq @ 19 psi, and 557 rwhp/533 rwtq @ 26 psi with the stock intake manifold. I made 525 rwhp/ 470 rwtq @ 19 psi, 604 rwhp/522 rwtq @ 26 psi, and 633 rwhp/544 rwtq @ 29 psi on my front facing intake with the .68 housing and 639 rwhp/ 574 rwtq @ 29 psi with the .81 housing and blowing out spark from 5800 rpm to 6700 rpm. I could have made more power if I could have revved higher and I didn't dyno again after I installed my DLI which fixed the ignition.
Sean
