psi
IETV8S
1.5JZ WOOT WOOT!
Mar 24, 2007
60
calgary
i couldnt find this information ne where, what is the stock p.s.i per cylinder supose to be?.....whats the lowest it can be at before you need to rebuild?
Shadow
87 1JZ-GTE Single Turbo
May 25, 2005
304
Windsor, Ct
Are you talking about the cylinder compression? If so, did you do a compression test? What kind of numbers did you come up with if you did one?
tissimo
Stock is boring :(
Melbourne, FL
similar numbers to the 7m.. if its under like 120 i'd start to worry, if they're all even is mainly what your looking for..
