Okay, I have a few questions regarding the power steering systems in the MKIII cars. -
- How do you identify the different types of racks from eachother to determine which one you have?
- Were they specific or did they interchange on TEMS cars?
- And what year did they change?
I'm going through the steering system on my car. It's an '88 MGTE (5spd, don't know if that makes any difference) w/TEMS. I'm slowly going through one piece at a time to correct the systems many problems. The pressure line failed on my brother when he was driving the car and he limped it home (driven about 5 miles). This ultimately took out the pumps primary shaft seal and a few of the other seals inside the pump. I have replaced the unit with a new one as well as all of the pressure line and return soft lines. It made a mess of things, but we have since cleaned everything back up since we replaced the turbo and head gasket when we bought the car in October of 2004.
I've been a member since then, off and on due to some of the hacks, but we've left the car alone since we fixed the leaks in the steering system. My brother has decided that he wants to continue working on the car, a little at a time to get it working and looking good.
He noticed the other day that the car was using ATF when he checked the Power Steering resivoir. We jacked the car up a couple of inches with the wheels still contacting the ground and did a throw test on the steering to see where the system was leaking from.
I have located the leak and it seems to be coming from the RH side primary shaft seal. It's dribbling out of the end of the boot on the rack.
Is there any way to replace the seal easily? I don't mind removing the unit if need be, as I had to take it loose to get the pressure line installed. I've been through it once already.
Has anyone here had any experience with these seals before?
Thanks!
Dave
Thanks!
Dave
