PS Hose Size?
Kyle87T
479
Richmond Hill, Ontario, Canada
I need to know the sizes of a few hoses. I am trying to get all the measurements in NPT or inches because I want to purchae my braided steel from one company and not have to travel everywhere to get different hoses for different measures.
I need:
Valve Cover nipples in NPT (1/2"???)
PS Resevoir Ports; Bottom, and Return in NPT (3/8" and 5/8"???)
Master Cylinder Hoses in NPT (3/8"???)
I have all the FPR lines in braided steel so if there is any other hose that I missed that can be replaced with braided steel let me know.
Thank you.
89pearlwhite
23
Houston, TX
The PS reservoir hose size is 5/8". If you're talking about AN size it would be -11 AN. The PCV ports you're talking about are the twin nipples on the valve covers right? I believe they are 1/2", -9AN should be able to fit. HTH! Happy plumbing$$$$$:icon_lol:
89pearlwhite
23
Houston, TX
I believe the other hose for the PS should be approx. 3/8 " . Please double check yourself to be sure. Use your open end wrench to approximate the nipple size.
Adjuster
Well, most braided stainless line is rated higher than the 1500psi, but only when used with the right fittings. :)
Clamps will not cut it for long at those pressures in my experience.
The return size on the PS is AN11.
I use Earl's pushlock hose with clamps off the valve covers, and I belive it's 1/2" ID.
Fuel lines are AN6.
Stock oil cooler lines are also AN6 IIRC. (I use the stock oil cooler as my PS cooler now.)
Good luck.
