Hi all,
I'm wanting to put a proportioning valve into my braking system to adjust the bias. I'm using the 13" cobra fronts, with mk4 2 pot rears. I have ABS and I am keeping ABS.
From my calcs i'll be having too much rear bias so i need to shift it to the front, or at least have the ability to do it. Does anyone know if there's any adjustable proportioning valves that will install with minimal work?
What is the thread and pitch of the stock brake line connectors?
Am i correct in saying you put the prop valve on the rear brake lines, not the fronts?
