I've thrown this idea around for at least a year and I have a ct26 that I plan to put in. I've asked around on some jeep forums but I think the idea of a turbo is taboo to most jeep owners. To them turbos only belong on hondas and every single turbo has massive lag. I've caught alot of flack and I'm looking to prove these guys wrong. I picked a ct because it isn't a tiny turbo but it should be slightly small for the 4.0 inline 6(and partially because I have a supra and already had a ct). The 4.0 is a low end torque monster and not a high revving motor so I'm hoping this small of a turbo will put the power right where I need it and not choke out on the top end. I plan to do a similar setup to this guy,http://www.jeepforum.com/forum/showthread.php?t=661277, but plan on doing a front mount and using a FTC-1 piggyback/larger injectors from Split Second to tune the engine. I'm thinking up the questions as I go so I'll be back time and again with them. Try to keep the bashing to a minimum I'm already catching it from my jeep friends.
1) The ct can't be turned on its side right? The oil intake has to be on the top and the drain on the bottom, not side to side? It would be way easier to pipe if I could.
2) Where would be the best place to run the oil from? Kit maybe? How do the na-t guys do it?
3) Anybody live near Knoxville that wants to help?:naughty:
